    SavePalestine SmileFlag SavePalestine SmileFlag SavePalestine SavePalestine PageHits: 1202927
    BSDForAll.Org | Forums BsdforALL (Public Forum) You can help today! Why do boycott systemd?
    New Reply
    Threads: 200
    10-25-2024, 06:58 AM
    Quote:Taken from: https://without-systemd.org/wiki/index_p...g_archive/
    Check out the uselessd project for a saner systemd base.
    systemd is a replacement for the sysvinit daemon used in GNU/Linux and Unix systems, originally authored by Lennart Poettering of Red Hat.
    It represents a monumental increase in complexity, a slap in the face to the Unix philosophy, and its inherent domineering and viral nature turns it into something akin to a "second kernel" that is spreading all across the Linux ecosystem.
    This site aims to serve as a rundown and a wake-up call to take a stand against the widespread proliferation of systemd, to detail why it is harmful, and to persuade users to reject its use, and especially its ubiquity.
    Disclaimer: We are not sysvinit purists by any means. We do recognize the need for a new init system in the 21st century, but systemd is not it.
    The Rundown
    1. systemd flies in the face of the Unix philosophy: "do one thing and do it well," representing a complex collection of dozens of tightly coupled binaries.[1] Its responsibilities grossly exceed that of an init system, as it goes on to handle power management, device management, mount points, cron, disk encryption, socket API/inetd, syslog, network configuration, login/session management, readahead, GPT partition discovery, container registration, hostname/locale/time management, mDNS/DNS-SD, the Linux console and other things all wrapped into one. The agenda for systemd to be an ever-growing and invasive middleware for GNU/Linux was elucidated in a 2014 GNOME Asia talk.[2] Keep it simple, stupid.
    2. systemd's journal files (handled by journald) are stored in a complicated binary format, and must be queried using journalctl. This makes journal logs potentially corruptible, as they do not have ACID- compliant transactions. You typically don't want that to happen to your syslogs. The advice of the systemd developers? Ignore it. The only way to generate traditional logs is to run a standard syslogd like rsyslog alongside the journal.[3] There's also embedded HTTP server integration (libmicrohttpd). QR codes are served, as well, through libqrencode.
    3. Since systemd is very tightly welded with the Linux kernel API, different systemd versions are incompatible with different kernel versions and portability is unnecessarily hampered in many components. This is an isolationist policy that essentially binds the Linux ecosystem into its own cage, serving as an obstacle to developing software portable with both Linux variations and other Unix-like systems. It also raises some issues backporting patches and maintaining long-term stable systems.
    4. udev and dbus are forced dependencies. In fact, udev merged with systemd a long time ago.[4] The integration of the device node manager, which was once a part of the Linux kernel, is not a decision that is to be taken lightly. The political implications of it are high, and it makes a lot of packages dependent on udev, in turn dependent on systemd, despite the existence of forks, such as eudev. Starting with systemd-209, the developers now have their own, non-standard and sparsely documented sd-bus API that replaces much of libdbus's job, and further decreases transparency. Further, they intend to migrate udev to this new transport, replacing Netlink and thus making udev a systemd-only daemon.[5] The effects of this move are profound.
    5. systemd features a helper which captures coredumps and directs them either to /var/lib/systemd/coredump... or the journal, where they must be queried using coredumpctl.[6] The latter behavior was a default and is likely to return.[7] It assumes that users and admins are dumb[8], but more critically, the fundamentally corruptible nature of journal logs makes this a severe impediment, and an irresponsible design choice. It can also create complications in multi-user environments related to privileges.
    6. systemd's size makes it a single point of failure. As of this writing, systemd has had 9 CVE reports, since its inception in March 2010[9](truncated; not all entries apply). So far, this may not seem like that much, but its essential and overbearing nature will make it a juicy target for crackers, as it is far smaller in breadth than the Linux kernel itself, yet seemingly just as critical.
    7. systemd is viral by its very nature, due to its auxiliaries exposing APIs, while being bound to systemd's init. Its scope in functionality and creeping in as a dependency to lots of packages means that distro maintainers will have to necessitate a conversion, or suffer a drift. As an example, the GNOME environment often makes use of systemd components, such as logind, and support for non-systemd systems is becoming increasingly difficult. Under Wayland, GNOME relies on logind, which in turn requires and is a part of systemd.[10] More and more maintainers are going to require systemd for this reason, and similar instances like it. The rapid rise in adoption by distros such as Debian, Arch Linux, Ubuntu, Fedora, openSUSE and others shows that many are jumping onto the bandwagon, with or without justification. Other dependent packages include the Weston compositor, Polkit, upower, udisks2, PackageKit, etc. It's also worth noting that systemd will refuse to start as a user instance, unless the system boots with it as well - blatant coercion.[11]
    8. systemd clusters itself into PID 1, rather than acting as a standalone process supervisor. Due to it controlling lots of different components, there are tons of scenarios in which it can crash and bring down the whole system. We should also mention that in order to reduce the need for rebooting, systemd provides a mechanism to reserialize and reexecute systemctl in real time, however, if this fails, of course, the system goes down. There are several ways that this can occur[12], including an inability to reload a previous, potentially incompatible state. This happens to be another example of SPOF and an unnecessary burden on an already critical component (init).
    9. systemd is designed with glibc in mind, and doesn't take kindly to supporting other libcs all that much.[13] In general, the systemd developers' idea of a standard libc is one that has bug-for-bug compatibility with glibc.
    10. systemd's complicated nature makes it harder to extend and step outside its boundaries. While you can more or less trivially start shell scripts from unit files, it's more difficult to write behavior that goes outside the box, what with all the feature bloat. Many users will likely need to write more complicated programs that directly interact with the systemd API, or even patch systemd directly. One also needs to worry about a much higher multitude of code paths and behaviors in a system-critical program, including the possibility of systemd not synchronizing with the message bus queue on boot, and thus freezing. This is as opposed to a conventional init, which is deterministic and predictable in nature, mostly just serially execing scripts.
    11. Ultimately, systemd's spread is symbolic of something more than systemd itself. It shows a radical shift in thinking by the Linux community. Not necessarily a positive one, either. One that is heavily desktop-oriented, choice-limiting, isolationist, reinvents the flat tire, and is just a huge anti-pattern in general. If your goal is to pander to the lowest common denominator, so be it. We will look for alternatives, however.
    12. systemd doesn't even know what it wants to be. It is variously referred to as a "system daemon" or a "basic userspace building block to make an OS from", both of which are highly ambiguous. It engulfs functionality that variously belonged to util-linux, wireless tools, syslog and other projects. It has no clear direction, other than the whims of the developers themselves. Ironically, despite aiming to standardize Linux distributions, it itself has no clear standard, and is perpetually rolling.
    What can you do??
    • Boycott distros that use systemd.
    • Spread word of this web page.
    • Contribute to and use distros like Slackware, CRUX, Funtoo, and Gentoo that follow traditional Unix paradigms.
    • systemd alternatives include runit, OpenRC, s6, monit, perp, supervisord, Upstart, nosh and GNU dmd. Note that not all of these are meant as replacements for initd, specifically, even if they can theoretically be hacked in to be. Some are specifically designed for the task of process supervision and monitoring.
    • Consider migrating to *BSD, Plan 9 or something similar, if things get really out of hand.
    • Make an xBill mod that replaces Bill Gates' sprite with that of our great overlord Lennart Poettering. Maybe.
    • Research, work on and promote reimplementations of common systemd interfaces (hostnamed, localed, timedated, etc.) and their D-Bus APIs, which will facilitate running applications that depend on them, without the host system having to use systemd as its PID1. An OpenBSD GSoC developer is currently working on OS-agnostic, BSD-licensed replacements, which will likely prove the most viable. In the meantime, take a look at Gentoo's OpenRC-settingsd, as well as Canonical's systemd-shim and ubuntu-system-service. For udev alternatives, see Gentoo's eudev and Busybox's mdev (source).
    Users browsing this thread: 1 Guest(s)
    Please note that new posts in this forum must be approved by a moderator before becoming visible.
    Quick Reply
    Message
    Type your reply to this message here.
    You have selected one or more posts to quote. Quote these posts now or deselect them.
