    SavePalestine SmileFlag SavePalestine SmileFlag SavePalestine SavePalestine PageHits: 3549252
    BSDForAll.Org | Forums Operation Systems OpenBSD Installation of openBSD
    Threads: 238
    02-02-2024, 05:31 PM
    It's quite easy.
    Just download .img file from:
    (https://www.openbsd.org/faq/faq4.html#Download)
    I use usb stick for installing operation systems.
    on gnu/linux I type command fdisk -l and see the partitions list like that:
    Code:
    # fdisk -l
    Disk /dev/sda: 119.24 GiB, 128035676160 bytes, 250069680 sectors
    Disk model: SanDisk SD6SB1M1
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disklabel type: dos
    Disk identifier: 0xa2ac1348
    Device     Boot    Start       End   Sectors   Size Id Type
    /dev/sda1  *        2048   2099199   2097152     1G 83 Linux
    /dev/sda2        2099200 250069679 247970480 118.2G  5 Extended
    /dev/sda5        2101248  10489855   8388608     4G 83 Linux
    /dev/sda6       10491904  62920703  52428800    25G 83 Linux
    /dev/sda7       62922752 250069679 187146928  89.2G 83 Linux
    Disk /dev/sdb: 57.3 GiB, 61524148224 bytes, 120164352 sectors
    Disk model: Cruzer Blade
    /dev/sda is ssd from the laptop, but /dev/sdb the one I'd use for installing operation system is /dev/sdb. CD/DVD would be something like /dev/sr0
    so first we gotta localize, where install74.img is located.
    If it's /home/user/Downloads then
    Code:
    # cd /home/user/Downloads
    # dd if=install74.img of=/dev/sdb status=progress oflag=sync ds=4M
    After writing an image to the stick, we can reboot the laptop/PC and boot into openBSD. Installation is quite easy, the whole process is simple. There's no gui, but still, it's simple ;-).
    To be continued...
    Users browsing this thread: 1 Guest(s)
