    SavePalestine SmileFlag SavePalestine SmileFlag SavePalestine SavePalestine PageHits: 656522
    BSDForAll.Org | Forums BsdforALL (Public Forum) BSDforAll Using virtual machine and installing joborun
    Threads: 236
    02-17-2024, 08:27 AM (This post was last modified: 02-18-2024, 08:56 PM by monsieur.)
    Hey
    So I gave myself a task to install Joborun on qemu virtual machine.
    For that I am going to need a gnu/linux .iso with arch-chroot scripts.
    For that I am going to use Hyperbola GNU/Linux-libre .iso on my usb stick.
    So first thing obviously is to put .iso into usb stick
    for that we gotta get into dir with the hyperbola.iso
    ls is for list directory
    cd is for change directory
    dd is for putting the .iso image into usb-stick
    fdisk -l is for list of currently mounted storage devices.
    /dev/sda are partitions of my laptop
    /dev/sdb is the usb stick
    so after localizing hyperbola .iso...
    Code:
    dd if=hyperbola-milky-way-v0.4.4-dual.iso of=/dev/sdb bs=4M status=progress oflag=sync
    [if=nameofthe.iso of=/nameof/partition]
    [Image: qemu1.png]
    As far as I know, to boot hyperbola .iso I need to have it on my laptop with the qemu .img files, and also on the cd/rom, usb-stick, whatever.
    Next we gotta create qemu image and run the installation
    *the last command is wrong*
    Code:
    qemu-img create -f raw img1 6G
    qemu-system-x86_64 -m 2G -cdrom hyperbola.iso -boot order=d -drive file=img1,format=raw
    so -m 2G means that 2G of ram memory will be allocated for the image
    -cdrom hyperbola.iso is name of ISO
    Don't forget to put -m xG into the command!
    [Image: JEWzJ9f.md.png]
    And voila!
    [Image: JEWzutV.md.png]
    [Image: JEXkKrB.md.png]
    Next thing that has to be done is to get joborun tarball from their website.
    This can be done by using web browsers like lynx and downloading the tarball from their website
    or simply:
    Code:
    wget https://sourceforge.net/projects/joborun/files/images/jobo-latest.tar.xz
    if wget is not installed then simply install it with:
    Code:
    pacman -S wget
    Because I am on QEMU right now and don't know how to copy paste there, I will localize the download link using lynx web browser
    Hey!
    So I managed to download joborun tarball to /tmp then did change directory to /usr/local/bin there's a script called joborun-setup
    I managed to run this script with
    Code:
    ./joborun-setup
    and voila!
    [Image: JEgJdWx.md.png]
    Now let's begin the installation!
    *I am going out soon, so will be offline. I will update the guide when I am back, cheers
    *To be updated*
    *Useful links*
    [url="https://wiki.archlinux.org/title/QEMU"]Arch Linux QEMU Wiki[/url]
    [url="https://git.disroot.org/joborun/web/src/branch/main/install.md"]How to install Joborun (Official joborun wiki)[/url]
    Threads: 236
    #2
    02-21-2024, 05:20 PM (This post was last modified: 02-21-2024, 05:39 PM by monsieur.)
    Append console=ttyS0,115200
    [Image: Screenshot-2024-02-21-19-31-42.png]
    Threads: 236
    #3
    02-22-2024, 12:20 AM
    I am now stuck with installing joborun on the VPS
    Arch Linux won't detect android (crap)phone to get usb tethering internet connection, there's now wireless interface too
    Other arch linux based distros won't even boot
    Gotta try devuan .iso and download arch-linux scripts seperately.
    Threads: 236
    #4
    02-22-2024, 10:06 AM
    I am going to try install joborun using devuan
    Maybe I will be able to install arch-install-scripts on devuan?
    Threads: 236
    #5
    02-23-2024, 10:18 AM
    Trying Alpine Linux now
    I need go boot into .iso, install arch-install-scripts and then joborun, that should do the trick
    Users browsing this thread: 1 Guest(s)
